Incomplete imported CAD file
Posted: Wed Jun 09, 2021 5:12 am
by Paria_S
Hi.
I have imported a CAD plan to Dialux 4 but some parts of CAD plan has been removed. It means that the CAD plan cant be imported completely. I found that the parts of CAD plan that I have used the "SPLINE" command, has been removed when I have imported the CAD plan to Dialux. Is there any solution for this issue?
Re: Incomplete imported CAD file
Posted: Wed Jun 09, 2021 6:56 am
Hi Paria_S,
DWG files containing polylines and splines cannot be interpreted correctly by DIALux. When importing such DWG drawings into DIALux, either the corresponding layers are missing or the DWG cannot be imported at all. We would recommend you to delete all polylines and splines in your DWG drawing and then try to import the DWG again into DIALux 4.13.
