NUMBERS ARE NOT FILLED IN CORRECT
wimvc
Post by wimvc » Fri Dec 27, 2019 3:55 pm
Since some time we had the problem that when we filled in nrs in the type in boxes , ( like size , beam angles , and a lot more ) that the cursor during the typing of the first number jumped back to the left side , what created a lot of wrong filled in nrs. Let say we want to type in 36.000 than what happend was ............ we type the 3 the cursor jumped back to the left side and when we typed the 6 , we saw in the fill in box 63 .000 , and this caused a lot of confusion , mistakes , and time to go check each time even simple nrs , and a lot of jumping left and right to put the cursor back where it was needed to fill in a number.
But we have found the cullprit , if auto correction is used in the windows 10 OS , than it see the box as full and let the cursor jump each time to the left or the beginning of the box. So if anybody have a similar problem , just disable the auto correction function , in the keyboard settings , under typing.
We use windows 10 with an high end amd proccesor and the version evo 4.13 dialux.
Re: NUMBERS ARE NOT FILLED IN CORRECT
Post by Csuleiman » Mon Dec 30, 2019 7:37 am
Hello wimvc,
Thank you very much for your important feedback and your helpful advice.
