Improvements
HenrikForsgren
Improvements
Post by HenrikForsgren » Tue Mar 07, 2017 10:01 am
Hello!
i was wondering if it is possible to make the userprofile for each room pop up and ask each time a new room is created, or atleast an option to make it happen?
i would also want a option that is the "standard" option of profile, as of right now i have "office and officespace" as the standard, but i would like to change that depending on the project.
i was also wondering if you would be able to make the "floorelement" less interactiv with walls and other elements due to errors popping up if i use the floorelement to close to a wall, since they easily overlap if i draw from an imported DWG file.
same goes for Roofs its pretty often there is a roof which isnt just a normal pitched roof.
its not just once a day i get an error and the program shuts down due to cutouts in floorelement due to a wall or maybe a roof or something.
i hope you understand what i'm after here.
since it's very easy to make pretty complex environments it's also easy to make the program shut down due to all kinds of stuff.
i would also like to make a polygon in a "round" shape. for hills and stuff.
Re: Improvements
Post by T.Magenheimer » Thu Mar 09, 2017 10:24 am
Dear HenrikForsgren,
Thank you very much for your detailed feedback. We appreciated it.
We also will put all your points on our improvement list.
