EVO 9.0 Road
jakob Zeihlund
EVO 9.0 Road
Post by jakob Zeihlund » Tue Apr 07, 2020 9:46 pm
I do only use Evo for road calculations'
for quite a long time we have been missing some simple tools that actually is both in 4.13 and ind the indoor part
When will it be possible set the R-table to a value as default?
When will it be possible set the maintenance factor to a value as default?
When will it be possible take a standard set of requirements in 13201.2 and edit and save this fx as a danish lighting class?
when will it be possible to make a quick circular calculation surface fx for roundabouts?
when will it be possible to have an streetcalculation field in an outdoor scheme as in 4.13
is it now possible to have more outdoor scenes in one file fx if you make two different solutions?
is it possible to have the old verry short planning sheet back with roadsetup lightsetup and result on one page
PS thanks for the oppurtunity to have the imported draving on the results
BR Jakob
Re: EVO 9.0 Road
Post by T.Magenheimer » Thu Apr 16, 2020 7:31 am
Hello jakob Zeihlund,
We will forward your suggestions to our product owner. They will discuss your issue intensively and add your wish to our improvement list for future evo versions. Thank you for your important feedback!
jakob Zeihlund
Re: EVO 9.0 Road
Post by jakob Zeihlund » Fri Apr 24, 2020 4:00 pm
less talk more action yes please
I wrote the same comments 3 years ago
and on 3 page summary you cant add in the calculation grid
I am sorry to say it is not good enough
BR jakob
Re: EVO 9.0 Road
Post by kvkozierowski » Mon Apr 27, 2020 6:04 am
Hello Jakob,
To be a bit more precise, major road lighting improvements in evo are not a priority right now.
We will improve the field arrangement like we did with the line arrangement, fine tune the documentation and hopefully implement emergency lighting. Propably none of your wishes will be implemented within the next year or so. After that, may be if it seams to be an important thing for many users.
