Emergency Lighting Results at Floor Level
J_F
Post by J_F » Tue Jun 28, 2022 11:20 am
Dear Dialux,
The calculation objects/Emergency Light Scene option in the documentation list is very useful for rapid overview of the results. however only results at working plane level are shown. Is there an option for emergency lighting results at 0m/floor level?
Thank you
J_F
Re: Emergency Lighting Results at Floor Level
Post by J_F » Tue Jul 12, 2022 8:22 am
Could someone respond as my customers are awaiting an answer. Thanks
Post by kvkozierowski » Wed Jul 13, 2022 5:59 am
Hello J_F,
The emergency lighting results are already at floor level (0.0m) if you do not change the height of the anti panic surface or escape route:
What do you mean by "however only results at working plane level are shown"?
J_F
Post by J_F » Thu Jul 14, 2022 7:13 pm
Dear Kolja,
Thank you. This means I will have to insert an anti panic surface for every room <60m2.
Is there a way a room with just a working plane of 0.8m can be shown at 0m in the emergency lighting output without an anti panic surface?
Post by kvkozierowski » Fri Jul 15, 2022 7:02 am
Hello J_F,
It is not possible to do this, the working plane and anti panic surface are two very different calculation objects. You can add an anti panic surface with just one click.
Users browsing this forum: Semrush [Bot] and 1 guest
