Sketchup Export to Dialux
I've had some trouble exporting a sketchup file to 3ds and into Dialux. Nearly all of the surfaces correctly export, including the correct materials etc., but there are a few surfaces that simply disappear once imported into Dialux. I'm not sure if the sketchup construction is incorrect, or if Dialux is reading it correctly. See screenshots attached.
- Attachments
- here is the snapshot from dialux showing the issue
- dialux issue.PNG (129.38 KiB) Viewed 12444 times
- This is how the model should look, snapshot from sketchup
- sketchup.PNG (111.98 KiB) Viewed 12444 times
Re: Sketchup Export to Dialux
Hello Idermyer,
It looks like the faces of the SketchUp model are not orientated in the right way.
You have to check this in SketchUp : "view" "face style" "monochrom", now you can check: all faces have to be white, purple-coloured faces are not correctly orientated, you can change this by rightclick the face and choose "reverse face".
Users browsing this forum: No registered users and 8 guests
