API interface / emergency lighting example
Hello All - I have a question regarding Dialux EVO - is there an API available - or any other sort of interface that allows for automation ?
Re: API interface / emergency lighting example
Hi mikeallen,
Unfortunately, DIALux evo has neither an API interface nor an SDK that is controlled externally. We regret that we cannot help you in this matter.
DIALux · Technical Support
Thanks for letting me know - as a quick follow up question - is it possible then, to export a file - then make some changes to the file and import it or is it possible to export the file - edit / add some additional information before importing to another app ? - I have been asked to see what tasks can be automated as we are trying to automate as many tasks as possible in our work environment ( we are going through a digital transformation)
Hi mikeallen,
In evo you have the possibility to use the import function for DWG/DXF drawings, STF, IFC and 3DS files. The only interface for an export function applies to DWG/DXF drawings.
