Glare ratio calculation
JohnLanghout
Post by JohnLanghout » Mon May 14, 2018 2:42 pm
I'm calculating for a soccer field. The GR has to be below 50. To be sure I meet the requirements, I now put over the soccer field GR observers in a grid of 10 by 10 meters. When done so I have to check the output and check every line for the result.
Is there an other way to do this? For instance a measurement layer which gives the results just like the average with ISO lines but than with the ISO lines for the GR values?
John
Re: Glare ratio calculation
Post by Csuleiman » Wed May 16, 2018 8:07 am
Dear John,
If you would like to get a grid of GR observers, then there is no other possibility as to insert several GR observer points to the required positions.
