When I perform lighting calculations using Dialux 4.13 and generate the calculation report, I see two different sets of results for the calculated lux levels depicted in the calculation plan from the calculated lux levels in the output reports that gets generated. There isn't coherence between the calculated lux level points in the two sheets (calculation plan sheet and calculation report sheet). The attachments (2 files) will make my query clear.
Please clarify if this an error in the way I am making the software conduct lighting calculations or is just something to do with the settings in the software.
I seek help in this regard.
Different lux levels depicted in the calculation sheets
- Attachments
- calculation plan grid points.jpg (155.47 KiB) Viewed 3315 times
- calculation sheet grid points.jpg (170.2 KiB) Viewed 3315 times
Re: Different lux levels depicted in the calculation sheets
Dear Bushair,
Please have a look at the following thread to answer your question:
https://dxboard.dialux.com/viewtopic.ph ... ew#p105219
