Display values for sports lighting
gaubhat@gmail.com
Post by gaubhat@gmail.com » Sat Feb 09, 2019 7:14 pm
Hi there, I'm doing sports lighting in dialux 4.13 After adding luminaries and doing calculations, the values that I got on grid ( the pink values) are very different than those that are printed on report in pdf. If I'm getting E avg as 500 in the display val yes (the pink values) , then I get only 240 in the report, What could ber the issue? Please help me.
Re: Display values for sports lighting
Post by Csuleiman » Mon Feb 11, 2019 9:39 am
Dear gaubhat@gmail.com,
When working with the real-time calculation feature you will get results, which are calculated in real-time. The output shows you the regular calculation, which is accurately.
You will always get the right calculation results after calculating the scene. The real-time calculation is just a rough overview of results (overhead calculator). It is helpful during the lighting planning. So to be sure that you will get the correct results, you need to calculate in the normal way the whole project.
