i am importing a corner to a recessed linear system (Dextra Lighting RWY COR L20 TW OP C84).
when i import the LDT it appears as a straight 1m length, not a 550mm x 550mm corner as it should.
is there a way i can modify the LDT/IES file to change it to a corner shape?
it works in relux i'm told by Dextra and appears as the correct corner shape
Linear bend appears as straight length
Re: Linear bend appears as straight length
Hello declanmorgan25,
You can use our LDT Editor to modify LDT files: https://www.dialux.com/en-GB/download#c1776. There you have the possibility to change the geometry of the luminaire to your needs.
