MF standard
HenrikForsgren
MF standard
Post by HenrikForsgren » Wed Jun 12, 2019 7:04 am
I would like to be able to implement my contries own standard for using the CIE 97:2005 standard for determining the MF.
For example, Sweden has adapted the 2nd edition of the standard for the Swedish market, would be nice to be able to create my own list for this purpose
Edit:
It would also be pleasing to be able to change the standard reflection for a project early on, instead of 70/50/20.
Re: MF standard
Post by Csuleiman » Thu Jun 13, 2019 8:02 am
Hello HenrikForsgren,
Thank you very much indeed for your important feedback. We are happy to pass all topics on to our product owners. They will discuss the issues and add them to our evo improvement list as new wishes. The topics will then be estimated and prioritized according to the effort.
Re: MF standard
Post by kvkozierowski » Thu Jun 13, 2019 8:13 am
Hello Henrik,
You can already create a copy of the european CIE97 template and create profiles according to your local standards in evo. You can find it under File->Settings...->Standards.
HenrikForsgren
Re: MF standard
Post by HenrikForsgren » Fri Jun 14, 2019 8:46 am
Hello Henrik,
Please show me how i change the "very clean", "clean", "normal" and so on and also the value of each.
i cant find it anywhere.
Re: MF standard
Post by kvkozierowski » Fri Jun 14, 2019 11:48 am
To edit a profile you need to create a copy first, you cannot change the default profiles.
You can change the selection but not the value of "Clean" etc. for the ambient condition.
I am not sure if this will be implemented at all. For example for the daylight calculation there is an internal lookup table that determines the light loss factor of a window according to the selected ambient condition (inside) an pollution category (outside), this won't no longer work with user defined values.
Do you have differing values in the Swedish version of the standard?
HenrikForsgren
Re: MF standard
Post by HenrikForsgren » Thu Jun 20, 2019 9:08 am
And thats why i asked for this in "wishes" since Sweden dont use the standard right of the bat.
its kinda annoying having to change the values each time...
