How to keep DWG in Calculation after we close
bavarian
Post by bavarian » Mon Jul 15, 2019 3:29 am
Dear All,
Is this normal when i done with the calculations and everyhting, i saved and closed the program.
The problem is when i open the file again, the dwg is missing like "error to load".
I'm sure the path is fine and still exists. Is there any method to keep the DWG remain in the Dialux Evo Files even though we may save online without the CAD files.
It is frustrating to re-loading the plan one by one.
Thanks for the suggestions.
LuHü
Re: How to keep DWG in Calculation after we close
Post by LuHü » Tue Jul 16, 2019 7:50 am
Hey bavarian,
you can embed the plan into your project-file.
There is a checkbox under "construction", "plans" and then "save options".
Have a look at the attached screenshot:
Saving DWG-File.JPG (210.83 KiB) Viewed 2118 times
As I know, when the box is "unchecked" and you place your project-file or the DWG-plan in another folder, DIALux can't refind the plan.
So you just have to check the box and the plan is part of the DIALux-file.
Disadvantage is that large plans result into a much bigger project-file sizes!
Hope this helps!
Regards!
Lukas
Lukas Hünting
