problem - crashing
charalambos
problem - crashing
Post by charalambos » Wed Sep 25, 2019 1:07 pm
Dear Sirs,
My Dialux 4.13 is crashing and making the project files from .dlx to .dl~
I need to recover them as it is too many days work.
Thank you
Re: problem - crashing
Post by Csuleiman » Thu Sep 26, 2019 5:34 am
Dear charalambos,
In case of such problems, there remains always a possibility to get at least a part of your data back. For this, there is the backup file. Backup files are generated automatically by DIALux every time when saving.
The backup file is located at the same folder as the original file and equally named, but with the additional extension "BAK". The typical structure is "project name.evo.bak".
You can convert backup files to project files by yourself. The backup file needs to be renamed from "project name.evo.bak" to "project name 1.evo".
After renaming it, the file should be readable as every other DIALux project file.
charalambos
Post by charalambos » Thu Sep 26, 2019 5:49 am
