How to Restore the Preview Effect of IES Files'Light Intensity Distribution in Win10 Explorer
whalelight
Post by whalelight » Tue Oct 15, 2019 8:44 am
As the title shows, my new computer system is Win10. When I change the format of open files from Notepad to IES VIEWS SOFT, the content of picture 1 in Explorer becomes the content of picture 2. Could you tell me how to repair it? I've tried regedit tools to delete Association formats, but it doesn't work.
Re: How to Restore the Preview Effect of IES Files'Light Intensity Distribution in Win10 Explorer
Post by Csuleiman » Wed Oct 16, 2019 8:29 am
Hello whalelight,
Regarding your problem, I would like to provide you with a short instruction wherewith you can fix the problem.
At first open the registry : (type regedit in the white space under your start button)
Please follow this path : „HKEY_CURRENT_USER" -> "Software" -> "Microsoft" -> "windows" -> "CurrentVersion" -> "Explorer"
-> "FileExts" and delete the folder “.ies”.
After that please search for the file "_RegDll.bat" by using the Windows search function (the standard directory is C:\....\DIALux\Support). Now please run the "_RegDll.bat" batchfile by double-clicking it, so that all DIALux components will be registered manually. A Dos window will appear and you will get a message box for every single module. Please confirm every messagebox with a click on OK, if the registration step was successful.
It should work after a PC restart.
whalelight
Post by whalelight » Fri Oct 18, 2019 5:50 am
I am very grateful to your team for their response!
I have solved this problem, through the instructions you provided.
The software I installed is EVO 8.2, and the file named "_RegDll.bat" was not found in its installation path and in the entire computer file. (C:\Program Files\DIAL GmbH\DIALux\Register.bat?)
So I deleted the files in the following 4 paths and then reinstalled the software. At the moment the installation was completed, its display changed.
1.\HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.ies
2.\HKEY_CURRENT_USER\Software\Classes\.ies
3.HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.IES
4.\HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\RecentDocs\.IES
