Reducing glare
gaubhat@gmail.com
Reducing glare
Post by gaubhat@gmail.com » Fri Nov 01, 2019 5:20 am
Hi there,
What can i do to reduce the Glare rating (GR)?
When I inserted some observers in outdoor sports scene,I got GR less than 50,but few points showing reading 55.
As per standards,GR should be less than 50.
So what changes shall I do to make GR less than 50 at all points.
Will using lumianire other than LED whelp me?
-Gaurav
Re: Reducing glare
Post by Csuleiman » Fri Nov 08, 2019 10:11 am
Hello Gaurav,
The result of the GR value depends on many factors. The parameters defined by the user (maintenance factor, heights, positions...) are essential. For example, the reflection of the adjacent objects plays an important role and the luminaire arrangement. So you could try to reduce the luminaires. Since there is no error in our software, we cannot offer you a concrete solution. You simply have to play around with the luminaires until you get the desired glare.
