Unable to create building contour
lh2004.hr
Post by lh2004.hr » Fri Nov 15, 2019 10:09 am
Hi, I am new to Dialux evo and currently learning this software.
I have import dwg drawing but unable to create new building as whenever I tried to close the polygon, the option was greyed out.
Can anyone help me what should I do? as I am quite sure that problem is not due to autocad drawing as I have tried with few other drawings but still having the same issue.
Thank you
Re: Unable to create building contour
Post by Csuleiman » Fri Nov 15, 2019 10:46 am
Hi lh2004.hr,
We would like to ask you to send us your evo project file and a video with the workflow until the problem occurs. We will try to reproduce the problem you described. As soon as we have been able to propose a solution, we will contact you again.
lh2004.hr
Post by lh2004.hr » Mon Nov 18, 2019 8:39 am
Dear Sir/Mdm,
I have sent the e-mail for the topic link as well as dropbox link for downloading the autocad file, for your further guidance.
E-mail was sent to : 'Support@dial.de', as requested.
Thank you for your assistance.
Post by T.Magenheimer » Mon Nov 18, 2019 6:37 pm
Dear lh2004.hr,
The problem is caused by a wrong scaling. This scaling is much too high. We also sent you a mail with an explaining screenshot. With this unrealistic size of a building, the building contour can no longer be closed. Please correct the scaling. Then the problem is also solved.
