Indirect lighting
nostos
Indirect lighting
Post by nostos » Tue Jan 14, 2020 9:59 pm
Hello everyone,
I am new to Dialux Evo. I can build a floor of a building with the rooms, calculation areas, and run the calculation with different direct light luminaries but I was wondering if there is a way to make a decent lighting calculation through indirect lighting. In particular I would like to try LED strips in aluminium profiles directing the light up to the ceiling and then have a calculation area on the floor or slightly off the floor by reflection.
I would appreciate any suggestions
Re: Indirect lighting
Post by Csuleiman » Wed Jan 15, 2020 7:14 am
Hello nostos,
There are two alternatives to plan cove lighting. Either you use room elements or you use a suspended ceiling, which you would, of course, have to cut out.
nostos
Post by nostos » Thu Jan 16, 2020 6:37 pm
Thank you CSuleiman for your suggestion
I followed it and got the lux isolines on the calculation area near the floor. The values are sensible but I have read that only 10 to 30% of indirect lights reach the floor from reflection off the ceiling. Can you tell me if Dialux Evo has a parameter to influence the percentage of this reflection percentage and what are the range of values you can give it?
Post by Csuleiman » Mon Jan 20, 2020 9:57 am
Hello nostos,
Unfortunately, evo has no such parameter.
