Dialux Evo Restarts when loading file.
Alexhuu93
Post by Alexhuu93 » Mon Feb 10, 2020 8:47 pm
Hello! I have a problem when trying to open ANY saved file in dialux 8.2.
As soon as i click the file i want to open, it loads for a bit, and then:
"Fatal error occurred when loading the file C:\Users\xxxxxxxx\AppData\Local\DIAL GmbH\DIALux\test.evo
The program will be restarted"
Is there a patch or a workaround for this? i really love the program but i can't really work with it when i can't open saved files.
I have a Lenovo P50, running windows 7 Enterprise SP1.
Since it is a work-computer and we have strict IT-policies i can't really do much about my Operating System. i have _some_ admin-privileges but not complete.
Alex
Re: Dialux Evo Restarts when loading file.
Post by Csuleiman » Tue Feb 11, 2020 6:55 am
Hello Alex,
Please make sure that your user account has full access (read and write) to the complete directory 'C:\Users\PC\AppData\Local\DIAL GmbH\DIALux\'.
If you have full access, please reinstall evo.
We recommend that you completely uninstall your current evo version from your computer system and install our latest evo 8.2 patch 1 version using the following download link. In this case, all DIALux components will be re-registered.
DIALux evo 8.2 patch 1: https://b2b.dial.de/index.php/s/remTwgv87qPCEJz
Alexhuu93
Post by Alexhuu93 » Tue Feb 11, 2020 2:55 pm
Hello and thanks for the fast response.
I tried this and it did not work.
I also have another problem when i reinstall.
"Unbehandelte Ausnahme: Exception has been thrown by the target of an invocation.
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Delegate.DynamicInvokeImpl(Object[] args)
at Dial.Dialux.Classlib.Tools.ModuleLoader.InvokeRegisteredInitMethods()
at Dial.Dialux.Classlib.Tools.ModuleLoader.InitializeModules(IEnumerable`1 modules, Action preDelayedInitAction)
at Dial.Dialux.Gui.DIALuxModuleLoader.InitializeModules()
at Dial.Dialux.Gui.MainWindow.DelayedOnLoaded()
Inner Exception:
System.ArgumentException
The directory name C:\Users\<UserName>\AppData\Local\DIAL GmbH\DIALux\RecentFurnitures is invalid.
at System.IO.FileSystemWatcher..ctor(String path, String filter)
at Dial.Dialux.InteractionCatalogs.Utilities.ObjectProviderFileWatcher..ctor(IDispatcher dispatcher, IObjectProvider objectProvider, String path, String filter, String logWarningMsg)
at Dial.Dialux.InteractionCatalogs.Provider.FurnitureObjectProvider.DelayedInit(ModuleLoaderEventArgs args)"
and also
"Unbehandelte Ausnahme: Could not find a part of the path 'C:\Users\<UserName>\AppData\Local\DIAL GmbH\DIALux\UserRTables'.
System.IO.DirectoryNotFoundException
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileSystemEnumerableIterator`1.CommonInit()
at System.IO.FileSystemEnumerableIterator`1..ctor(String path, String originalUserPath, String searchPattern, SearchOption searchOption, SearchResultHandler`1 resultHandler, Boolean checkHost)
at System.IO.DirectoryInfo.InternalGetFiles(String searchPattern, SearchOption searchOption)
at Dial.Dialux.StreetLighting.CalculationManager.RTableCollection.UpdateFromDirectory(IContext context, String path, Boolean userDefined)
at Dial.Dialux.StreetLighting.CalculationManager.RTableCollection.Update()
at Dial.Dialux.StreetLighting.CalculationManager.CalculationManager.ProjectLoading(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at Dial.Dialux.Classlib.Extensions.EventExtensions.InvokeImpl(EventHandler handler, Object sender, Int32 maxExpectedListeners)
at Dial.Dialux.ProjectData.Management.ChangeManager.ReportProjectStatus(ProjectStatus projectStatus)
at Dial.Dialux.InteractionFileHandling.LoadSave.LoadSaveManager.LoadProject(FileInfo fileInfo)
at Dial.Dialux.InteractionProjectHandling.Base.ProjectHandling.LoadProject(String filename)
at Dial.Dialux.Gui.MainWindowFileHandling.OpenFile(String filename)
at Dial.Dialux.Gui.MainWindowFileHandling.OnCommandLoadProject(Object sender, ExecutedRoutedEventArgs args)
at System.Windows.Input.CommandBinding.OnExecuted(Object sender, ExecutedRoutedEventArgs e)
at System.Windows.Input.CommandManager.ExecuteCommandBinding(Object sender, ExecutedRoutedEventArgs e, CommandBinding commandBinding)
at System.Windows.Input.CommandManager.FindCommandBinding(CommandBindingCollection commandBindings, Object sender, RoutedEventArgs e, ICommand command, Boolean execute)
at System.Windows.Input.CommandManager.FindCommandBinding(Object sender, RoutedEventArgs e, ICommand command, Boolean execute)
at System.Windows.Input.CommandManager.OnExecuted(Object sender, ExecutedRoutedEventArgs e)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.Input.RoutedCommand.ExecuteImpl(Object parameter, IInputElement target, Boolean userInitiated)
at MS.Internal.Commands.CommandHelpers.CriticalExecuteCommandSource(ICommandSource commandSource, Boolean userInitiated)
at System.Windows.Controls.Primitives.ButtonBase.OnClick()
at System.Windows.Controls.Button.OnClick()
at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEventArgs e)
at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
at System.Windows.UIElement.OnMouseUpThunk(Object sender, MouseButtonEventArgs e)
at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)"
I solve this by creating a new folder inside DIALux folder called "RecentFurnitures" and one called "UserRTables"
When i solve these errors, the program works but i still can't load any saved files.
Could i be missing some important files inside those folders?
It kinda feels like its a problem caused by my companies softwares and/or privileges.
When i look at the dialux folder i can see i have read/write privilege though...
Alex
Post by Csuleiman » Wed Feb 12, 2020 12:40 pm
Hello Alex,
We would like to ask you to send us your instance ID of evo. You will find it in the menu "?" under "Info about DIALux evo...".
Please simply click on "Copy" in the window and paste the text into an e-mail as shown in the screenshot below.
Alexhuu93
Post by Alexhuu93 » Wed Feb 12, 2020 12:46 pm
Here is the info.
Version 5.8.2.41698
mf_Patch1 - C642066C0E
Quadro M2000M/PCIe/SSE2 / 64-bit / Calculation engine: 64-bit standalone
Support ID: 7f4fc61e50aad76bca5ffa846a845fdd
Alex
Alexhuu93
Post by Alexhuu93 » Wed Feb 12, 2020 12:48 pm
I emailed you guys now.
Thank you for the quick response!
Post by Csuleiman » Wed Feb 12, 2020 1:28 pm
This seems to be a rights problem on the computer.
In any case, you do not have access rights to your user folder - but you need read and write access here. We can only recommend that you contact your admin. This definitely seems to be nothing we can help you with.
Alexhuu93
Post by Alexhuu93 » Wed Feb 12, 2020 1:43 pm
Yeah i think so too. one other error i get is "Unbehandelte Ausnahme: Access to the path '\\xxxxxxxxxxxx.com\FolderRedir\SE\xxxxx\xxxxxxxxx\Documents\DIAL GmbH\DIALux\UserFurnitures' is denied."
the software routes everything trough our companies network. And that is closed. i will probably have to talk to our it-support..
Post by Csuleiman » Wed Feb 12, 2020 3:55 pm
Yes, you'd really better ask your IT guys about that.
