i import into dialux evo a drawing 3d autocad. Only appared border for for figures, no solid area.
malmcl
Post by malmcl » Mon May 04, 2020 12:13 pm
dear.
Regard
Re: i import into dialux evo a drawing 3d autocad. Only appared border for for figures, no solid area.
Post by Csuleiman » Mon May 04, 2020 12:36 pm
Hello malmcl,
Unfortunately, it is not possible to get a 3D DWG/DXF drawing in DIALux as a solid block. DWG and DXF files are only drawings used in the background of the CAD.
In your case, you could import a 3D mesh as a 3DS object or you can make use of the IFC interface.
Currently you have the possibility to either insert a .3DS object in our DIALux evo software and to carry out a light planning with it. With this method, however, it is difficult to create a proper documentation of the project, since our evo software does not recognize any buildings, floors or rooms.
Or you have the possibility to insert an IFC model. So far, we have only implemented a beta version of the IFC import in our evo software.
In our knowledge base you will find helpful information regarding the requirements of a good IFC import:
https://evo.support-en.dial.de/support/ ... ifc-import
The following link leads you to our video tutorial for the IFC interface: https://www.youtube.com/watch?v=BVcgHGAladQ\
