Values ​​are not satisfied, even when they exceed the minimum illumination.
BAU
Post by BAU » Fri Jul 24, 2020 2:43 am
When calculating my project, in the areas the minimum level of illumination is greater than that indicated in the standards (in my case 200 lx), however the result is not satisfactory because it is placed in red, I do not know why the value Nominal is always => 500 lx, maybe that is the error, but I don't know how to change it. Attached I send 2 figures where for my work area they must be 200 lx, in the other figure the results obtained are higher than 200 lx, but the result is not acceptable. Regards.
Sorry, I can´t to attachment the figures.
Re: Values ​​are not satisfied, even when they exceed the minimum illumination.
Post by Csuleiman » Fri Jul 24, 2020 6:13 am
Hello BAU,
You can change the profile settings and values in the tool “Spaces”. After selecting the corresponding space you can click on “Edit” and set the value as required. Please see screenshot below.
