CALCULATION SURFACE RESULTS ARE ZERO
raghunath293.p
Post by raghunath293.p » Mon Jan 04, 2021 10:22 am
After calculation, the results of all calculation surfaces are zero.
below is the dialux file https://we.tl/t-JJDYBGICYY
Raghunath
Re: CALCULATION SURFACE RESULTS ARE ZERO
Post by T.Magenheimer » Mon Jan 04, 2021 12:17 pm
Dear Raghunath,
We have looked at your project file and think that the project is just too complex for the DIALux calculation. The internal memory will eventually run out and thus the calculation will not be done completely.
You have a lot of large calculation areas and objects in your project. Delete once all calculation surfaces in your project and leave only one calculation surface in your project and then run the calculation again. If the calculation works, then the project is too complex and you have to make it simpler.
raghunath293.p
Post by raghunath293.p » Mon Jan 04, 2021 1:20 pm
Thank you....
