Light fixture sources are blue
Archtube
Post by Archtube » Thu Jan 14, 2021 8:01 am
I am experiencing something very strange after my calculations. After the calculation is done all the light sources turn light blue. This does not seem to affect the final result of lux values in any way. The surface where the light shines on does not seem to be affected either.
Has anyone else had this problem? If yes, is there any chance this has happened with the last update?
Re: Light fixture sources are blue
Post by T.Magenheimer » Thu Jan 14, 2021 8:42 am
Hi Archtube,
The behaviour of the luminaires is due to the white balance, which we changed in this new evo patch version. But, you can set the white balance to manual and probably fix it.
This is just a visual imperfection for which the current evo version only offers the possibility to correct the display via manual white balance. The calculation results are correct in any case.
We will correct this behaviour in our next evo version.
Screenshot 1.JPG (141.13 KiB) Viewed 1139 times
Archtube
Post by Archtube » Thu Jan 14, 2021 9:28 am
Thank you for your quick response. As it seems the solution you offered is not effective. Any other ideas of how this can be fixed? I need the renders for a client and I cannot submit it when the fixtures are blue. There will be a big misunderstanding!
Possible for you to send me the link for download of the last version of evo? Before the patch update?
Post by T.Magenheimer » Thu Jan 14, 2021 12:23 pm
Hi Archtube,
There is currently no other workaround for this issue and unfortunately we cannot send you the upcoming evo version in advance.
Archtube
Post by Archtube » Thu Jan 14, 2021 12:57 pm
I mean if you could send me the previous version of DIalux, Not the upcoming!!
Please, I need this ASAP
Post by Csuleiman » Thu Jan 14, 2021 1:01 pm
Hi Archtube,
We have made the changes only in the patch version of evo 9.1. This is previous evo 9.1 version without these visual effects, which you can download from the following link:
https://b2b.dial.de/index.php/s/gOGXRKPbYOFRIC0
