setting error
ahmady30
setting error
Post by ahmady30 » Mon Apr 26, 2021 2:15 pm
hello
when i click on generall seting this error shows me
Re: setting error
Post by T.Magenheimer » Mon Apr 26, 2021 6:48 pm
Dear ahmady30,
We would like to recommend you to uninstall your current evo version completely from your computer system and install our newest evo 9.2 version by using the following download link. In this case, all DIALux components will be newly registered.
DIALux evo 9.2 (patch 3) setup: https://b2b.dial.de/index.php/s/w1BRVtWm5hx8OhV
ahmady30
Re: setting error
Post by ahmady30 » Wed Apr 28, 2021 8:27 am
I did this but unfortunately the problem was not solved
Re: setting error
Post by Csuleiman » Wed Apr 28, 2021 8:34 am
Hello ahmady30,
We would like to ask you to provide us with the entire text of the error message. You can simply copy and paste the text from the error message into the thread.
ahmady30
Re: setting error
Post by ahmady30 » Wed Apr 28, 2021 12:12 pm
Untreated exception: Exception has been thrown by the target of an invocation.
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Delegate.DynamicInvokeImpl(Object[] args)
Inner Exception:
at System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck)
at System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
at System.Activator.CreateInstance(Type type, Boolean nonPublic)
at System.Activator.CreateInstance(Type type)
at Dial.Dialux.Gui.Controls.Main.ModeControlMapper.GetContentForMode(Type modeType, Type toolType)
at Dial.Dialux.Gui.Controls.Main.ModeSelectionControl.ShowContentForTabItem(ModeTabItem tabItem)
at Dial.Dialux.Gui.Controls.Main.ModeSelectionControl.SetSelectedTabItemForMode(IMode requestedMode)
at Dial.Dialux.Gui.Controls.Main.ModeSelectionControl.DispatchedSetMode(Mode mode)
Inner Exception:
System.Windows.Markup.XamlParseException
Set property 'Xceed.Wpf.Toolkit.Primitives.UpDownBase(System.Nullable(System.DateTime)).Value' threw an exception.
at System.Windows.Markup.XamlReader.RewrapException(Exception e, IXamlLineInfo lineInfo, Uri baseUri)
at System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, IXamlObjectWriterFactory writerFactory, Boolean skipJournaledProperties, Object rootObject, XamlObjectWriterSettings settings, Uri baseUri)
at System.Windows.Markup.WpfXamlLoader.LoadBaml(XamlReader xamlReader, Boolean skipJournaledProperties, Object rootObject, XamlAccessLevel accessLevel, Uri baseUri)
at System.Windows.Markup.XamlReader.LoadBaml(Stream stream, ParserContext parserContext, Object parent, Boolean closeStream)
at Dial.Dialux.Gui.Controls.Modes.Settings.SettingsModeControl..ctor()
Inner Exception:
System.ArgumentOutOfRangeException
Specified time is not supported in this calendar. It should be between 03/22/0622 00:00:00 (Gregorian date) and 12/31/9999 23:59:59 (Gregorian date), inclusive.
Parameter name: time
at System.Globalization.PersianCalendar.CheckTicksRange(Int64 ticks)
at System.Globalization.PersianCalendar.GetDatePart(Int64 ticks, Int32 part)
at System.Globalization.PersianCalendar.GetDayOfMonth(DateTime time)
at System.DateTimeFormat.FormatCustomized(DateTime dateTime, String format, DateTimeFormatInfo dtfi, TimeSpan offset)
at System.DateTimeFormat.Format(DateTime dateTime, String format, DateTimeFormatInfo dtfi, TimeSpan offset)
at System.DateTimeFormat.Format(DateTime dateTime, String format, DateTimeFormatInfo dtfi)
at Xceed.Wpf.Toolkit.DateTimeUpDown.<>c__DisplayClass48_0.<ParseValueIntoDateTimeInfo>b__0(DateTimeInfo info)
at System.Collections.Generic.List`1.ForEach(Action`1 action)
at Xceed.Wpf.Toolkit.DateTimeUpDown.OnValueChanged(Nullable`1 oldValue, Nullable`1 newValue)
at Xceed.Wpf.Toolkit.DateTimePicker.OnValueChanged(Nullable`1 oldValue, Nullable`1 newValue)
at Xceed.Wpf.Toolkit.Primitives.UpDownBase`1.OnValueChanged(DependencyObject o, DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
at System.Windows.Baml2006.WpfMemberInvoker.SetValue(Object instance, Object value)
at MS.Internal.Xaml.Runtime.ClrObjectRuntime.SetValue(Object inst, XamlMember property, Object value)
ahmady30
Re: setting error
Post by ahmady30 » Wed Apr 28, 2021 1:07 pm
I discovered that I have to change the date of the system to english. Of course, the tips that you also said was effective. I copied the message and read it once. Thank you, dear friend. :lol: :lol: :lol: :lol: :lol: :D :D :D
Re: setting error
Post by Csuleiman » Wed Apr 28, 2021 3:10 pm
Hello ahmady30,
You're welcome. We are glad that you were able to solve the problem yourself. :)
