Red/Green squadre in the Result overview
White
Post by White » Tue May 03, 2022 4:13 pm
Dear DIALux board,
is it normal that when I create a space I can define its utilisation profile which, by means the associated parameters, makes the grey square on the right corner of the result overview red or green depending on the average value, but when I create a calculate object and associate it to a space the square remain grey whatever?
Does the software allow to switch the red or green square on depending on minimal or maximum illuminance instead on average illuminance?
Thanks in advance.
My best regards.
Re: Red/Green squadre in the Result overview
Post by Csuleiman » Wed May 04, 2022 5:10 am
Hello White,
The traffic light symbol only indicates whether the target value of the average illuminance for the working plane is fulfilled or not fulfilled in relation to the selected utilisation profile. If you open the results for the working plane in the results overview, you will notice that no target value is entered next to the uniformity Emin/Em. Therefore, no traffic light colour is shown here.
Unfortunately, it is not possible to display so-called limit values for calculation surfaces. The traffic light view is only available for the working planes. For calculation objects it is not possible to get the traffic light feedback. Therefore the box for calculation surfaces is shown in grey.
I.e. these target values are only displayed for working planes according to EN12464, as you can also only assign a utilisation profile to one utilisation area.
White
Post by White » Wed May 04, 2022 10:55 am
Dear Csuleiman,
thanks for your kind answer.
Just to be sure, in the second In the second phrase you wanted to say: "If you open the results for the calculation surface in the results overview", didn't you? Becouse only for working planes I can find a set value in correspondence to the "Target" column and the "Average" line.
Thanks again and best regards.
Post by Csuleiman » Wed May 04, 2022 12:10 pm
Hello White,
Yes, indeed, that was a typo. You are absolutely right that I meant "calculation surface" and not working plane.
White
Post by White » Wed May 04, 2022 12:26 pm
Dear Csuleiman,
thanks a lot for your customary kindness and your exhaustive replies.
Have a nice day, my best regards.
Users browsing this forum: Semrush [Bot] and 4 guests
