Exterior vertical surface calculation
Post Reply
Eslav2
Post by Eslav2 » Sat May 21, 2022 8:25 am
I am trying to create vertical calculation surfaces along the boundary plot line of a very large irregular site. Is there a way to do this without doing lots of separate calculation surfaces and rotating them 90 degrees? I have tried to use ‘spaces’ but it doesn’t seem to help.
Re: Exterior vertical surface calculation
Post by T.Magenheimer » Tue May 24, 2022 7:19 am
Dear Eslav2,
If the site should be uneven, you have no other option than to insert several calculation surfaces. If the site is only angled on one level, you can work with a polygonal calculation surface.
Eslav2
Post by Eslav2 » Wed May 25, 2022 5:14 am
Thanks for your reply. When you mention 'polygonal calculation surface' do you mean to build the polygon shape on the horizontal and rotate it 90 degrees? Is there a way to construct an irregular polygon shape on the horizontal and extrude the surface up, similar to a wall?
Post Reply
Users browsing this forum: Ahrefs [Bot], AybegumD, Semrush [Bot] and 6 guests
