I suspect there is a geometry problem with this file. All of the walls on the Maintenance building 1st floor disappeared. There are still orange lines there, and the structure starts to reappear when I delete the rooms - But when I try to redraw the rooms, they are still in orange. any help you can provide would be appreciated.
Link to the file is here: https://drive.google.com/file/d/17WESRu ... sp=sharing
All the Walls disappeared on one of my buildings
Re: All the Walls disappeared on one of my buildings
Hello Daniell,
We were able to locate the error. It was a geometry problem, which we could fix directly in your evo project file. Under the following link, you can download the repaired evo project file: https://b2b.dial.de/index.php/s/GPYCZpAfc5nKlJT
Please check if the problem you described still exists or if you can continue working with this project status.
DIALux · Technical Support
Thank you for the help. I've seen you post that it was a geometry problem on several threads like this.
